What kind of clutch
What kind of clutch
Next week im going to be doing a lot of mods to my 98 gt including pi head swap, bbk lt headers,bbk o/r x pipe, bbk pullies , noszle nos kit , trick flow upper plenum , bbk 75 mm tb, im going to have the engine out and im going to change the flywheel so i might as well change the clutch what kind do you guys recommend. Thanks
RE: What kind of clutch
SPEC, Centerforce, Mcleod are all good clutches.
Since you're pulling your engine I thought I'd let you know that BBK LT headers cannot be on the heads when you drop the engine back in. There is no room because the K member gets in the way. I found this out the hard way. I then dropped the K member and found out that the passenger side header will not fit around the tranny. So I removed that header and it went right on. I never had to remove the driver side header. Good luck and have fun.
ya get either the SPEC stage 1 clutch kit... thatll handle the HP ur making .. i think its up to 450 HP... if not u can get the stage 2, or the king cobra clutch kit.... centerforce also makes good ones... my buddy has one of them and he likes it a lot.... either of those 3 clutches should make you a happy man
junior04
09-28-2015 10:53 AM
mrappe
09-26-2015 10:16 AM
