Replacing the 460 Mach speakers
My right rear speaker is blown, I have a pair of factory replacements, but I dont know how to get to the speakers, a howto or directions to one is needed. thanks
RE: Replacing the 460 Mach speakers
you might want to post questions like this in the stereo section... but i can help
for the back deck you have to unscrew about 6 bolt/nuts... look under the rear speaker area and you will see the holes where you can get to the screws.
I had a bit of a problem so i had to remove the rear hat rack from the inside of the car by folding the seats down and unbolting the pad and then just removing the carpet.. then you can access all the bolts that hold the rear deck up...
Make sure you have some help, the rear deck + 2 amps is pretty heavy and if your not holding it you likely to have it fall and rip apart the speaker wires and amp wires.
Hope this helped a little bit!
