AT rear end Gears? question.
Old Apr 17, 2006 | 05:51 PM
03redGT's Avatar
03redGT
Default AT rear end Gears? question.
i have an AT in my car, which version is it in the gear calculator? is it the normal band or wide band.
at 20 mph in 1st gear, i was at 2,550 RPM thereabouts.
reason being, im trying to figure out if the previous owner had ford install gears. thanks
Old Apr 17, 2006 | 08:52 PM
mself52's Avatar
mself52
Default RE: AT rear end Gears? question.
gear calculator according to this i dunno what transmission you have but with 4.10 gears the 4r70w std 2.40 transmission would be around 2600rpms... the other one 4r70w wide 2.84 is over 3k rpms with 4.10's and 2400rpms with stock 3.27 gears.... sooooooo either you have the std with 4.10 or wide with 3.27 hahaha
Old Apr 17, 2006 | 08:55 PM
HaV's Avatar
HaV
just put a piece of tape on the drive shaft and have someone idle forward exactly one roll of the tires.. count the rotations..... that'll tell you what gears are in it the easy way.
Old Apr 17, 2006 | 09:03 PM
mself52's Avatar
mself52
so youd have to be under the car while someone is pushing it?
Old Apr 17, 2006 | 09:07 PM
03redGT's Avatar
03redGT
dont you see my dilema lol thanks for the driveshaft tip. ill probably put it up this weekend.
msavoia23
12
Jul 7, 2018 12:08 PM
Sep 1, 2015 08:16 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
inyadreems
Aug 21, 2015 09:10 AM
91StangOwner
Aug 20, 2015 11:34 PM
