Is 275/40/17 the tallest I can go
RE: Is 275/40/17 the tallest I can go
here is what i think i want 285/40/17
http://www.tirerack.com/tires/tires....e1=yes&place=2
ORIGINAL: djdalfaro
I still cannot imagine that even adding an inch to both sides would fill up the enormous gap. The reason I ask is that I found some 275/55/17 that i am considering purchaseing.
Those would be HUGE, don't do it, even if they do fit you will lose a **** load of bottom end...
ORIGINAL: mself52
ahhh good point i will check that out...but keep in mind that 27" is only half an inch on both sides
remember, front tires need to be able to TURN, too, without rubbing.
when the tire turns, it should be larger..it's a 3d object, remember, and it's moving on a different plane outward on one side, inward on another side... that outward side, is probably a tad wider at the extreme turns than the tire's given size.
ORIGINAL: mself52
hmmm why a 26? do you see the wheel gap on our cars? i measured and from the top of my 275/40/17 i have 3 and 3/4 inches of gap that is a freakin huge gap....i want to lower my car but i have to keep in mind longtube headers... so i will be lowering 1.6 front 1.5 back..... that will still leave a 2 inch gap how is it not possible to increase the tire size from 26" to 27 inch? so that i only have 1" gap? my handheld tuner can adjust the computer so that it believes the stock tire diameter is 27"
275/50/15's will fill up your wheel wells nicely. trust me.
55 is a big sidewall. what size wheel are you trying to put these on? i wouldn't put that on a stock 17x8 inch wheel.
ORIGINAL: mself52
i have the rims on my car in my sig... 17x9 cobra R's... and 285/40/17 will fit them fine
I was asking the thread starter about wheels.
275/50/15 and 285/40/17 are 2 completely different tires.
