Top speed in 4th gear with 4.10 in a '02 Gt 5 speed?
RE: Top speed in 4th gear with 4.10 in a '02 Gt 5 speed?
ORIGINAL: submit
Looks like about 110mph....
ORIGINAL: mustangman02232
it will be lower in 4th, however the gears will lower your top end so you can use 5th gear and reach a higher top speed
My 5.0 with 3.73's did a about 115 in 4th... so 4.10's should be similar in a 4.6 as it has a higher red line.
ORIGINAL: submit
well if you have a tr3650 like i believe you do and stock tire diameter.... your car will pull up to around 5800 rpms so over that HP actually decreases.... at 5800 rpms in 4th gear and 4.10 gears you are going 108.08 miles per hour....gear calculator 5th gear would be 174.322mph not that youd ever be able to go that fast
