Is my ET correct?
Is my ET correct?
Hi guys,
last night i want to BIC drag strip and tested my car "2000 GT", below is a list of what i have added to the car,
[ul][*] BBK LT ceramic coated headers[*] BBK 70mm T/B[*] BBK O2 elimnators [*] BBK under drive pullys[*] 2.5" custom exht system with X-pipe[*] FRPP king cobra clutch assy[*] FRPP 3.73s[*] pair of COMP cam's 226in/230exh 0.550[*] March ram air induction[*] MT ET street radials 275/40 R17
[/ul]
and my best et in 1/4 mile was 13.6sec.......
is that the best i can get out of that all, or some thing is wrong in car, i know its not tunned, but i thoght i would got beter time
feed back needed please..........
[/ul]
RE: Is my ET correct?
I think your car has a low (13.0-13.2) in it. If you havent ever been to the track or your not that experienced than you might have room for improvement there. What are your 60ft times? From your 60ft time we can kinda pinpoint what you need to work on.
What were your 60ft times?? How about your 330ft times?? Also, what RPM did you launch at??
For some reason, I think w/ a tune, and a little better driving, you could have a high 12... But I'd like to see more info from your timeslips..
JT
JT
You got 1.8 60's? Yeah then your ETs are bad. I got 13.7 at 100 w/ a 2.0 60'. And you have more stuff done than I do. Maybe not being tuned after cams is your problem. I don't know.
Is it an automatic??? and what kind of fuel did you put in it? What temp was it outside? What size is your "custom" exhaust......if your car is manual you should be better then that-if you can drive.....id except those #'s out of an auto....by the way how do you like those ET streets? I was thinkin bout those....
my car is manual, and i was using the normal fuel "87 octane" bahrain sh*t fuel, and my exht is 2.5inch,
regarding the ET streets, its just great driving with them on the car it doesn't mater what RPM u r going to luanch with on the strip or the street u still gona have a great grip
hows driving in rain? have u done that?.........Yeah Id personally run 93 in your car....with those mods...cause yoru not stock anymore....and get it tuned bro...youd be happy with results....
Defanitely get a tune, thats probably my only suggestion. With such a great 60 foot, you should defanitely see low low 13's with your mods. How fast do you shift gears? Maybe try and make it faster.
