Window Tint help?
Those dots at the top of the window are called Dot Matrix. The reason why most normal tint wont stick to the window is because it is made of a different surface then the other part of the window. Your two options for this is to either get a vinyl strip to cover it or get this stuff called Magoops that is used as an adhesive for the tint to stick where the dot matrix is.
I have tinted windows for a while and to tell u the truth every car comes out different with the dot matrix. if u would want them to tint the top strip they would have to retint the whole back window if u wanted it to look halfway decient. wht they neen to do is take a glue stick (blue one) and rub it across the dot matrix before aplying the window tint this helps the tint fall in between the dot matrix. the only other option i to do the vinyl
my back window is tinted all the way up and is fine. the tint shop lightly sanded the bubbles so the tint would stick. may help to light sand and clean before tint.
[IMG]local://upfiles/15919/3C8C9A789C3F4FF8B106EFA34291A9F4.jpg[/IMG]
if you are getting ready to tint a car the last thing u want is to be sanding or buffing anything thats going to stur up partical before u tint i dont care if u sand ur car 3 days before tinting it just creates more chance for ur window to come out with **** in it when u lay the tint on it and it drys
ORIGINAL: 35th99gt
Please pay attention to how old the threads are. How deep into the archives did you have to go to dig this thread up?
DreadPirateRoberts
Sep 26, 2015 02:11 PM
