engine code ?
Old May 1, 2006 | 01:48 AM
mike3219's Avatar
mike3219
Default engine code ?
the service engine soon light came on im my car today. i have an 01 gt. the code wasP0308. i went to get it scanned and it said that cylinder 8 was misfiring. what could be the problem. i am going to check the plugs and the coils. does anyone know what cylinder is eight. if anyone has a diagram it would be much appreciated. thanks
Old May 1, 2006 | 02:53 AM
Tac2cul's Avatar
Tac2cul
Default RE: engine code ?
could be time for new spark plugs....
also check for spark in #8 could be a bad coilpack
ha you have already said your gunna check them.....
#8 will be the one closest to the firewall on the drivers side
Old May 1, 2006 | 03:20 AM
97targa's Avatar
97targa
I suggest buying a Haynes manual.
Great for wiring diagrams and has all Torque specs
as well as OBDI/OBDII code references.
They are well worth $17.00
Also put a can of Greased Lightning Fuel Cleaner(it's awesome)
there could be carbon deposits that got to the plug!
Old May 2, 2006 | 03:11 PM
mike3219's Avatar
mike3219
thanks...appreciate the help guys
Old May 2, 2006 | 04:09 PM
mightyb28's Avatar
mightyb28
http://autorepair.about.com/cs/troub...l_obd_main.htm
P0308 Cylinder 8 Misfire Detected
Check the plugs, plug boots and ingnition system.
The link above will take you to the codes.
Go to pepboys and get yourself an ODB II scantron so you can turn it off after you fix it.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
zachary1988
Sep 4, 2015 03:04 PM
