Air Silencer
Old 05-01-2006, 11:58 AM
bsteen81
bsteen81's Avatar
Default Air Silencer
I just bought my first stang a week ago and would like to know where the air silencer is located so I can remove it. I have a 98 gt, stock intake.
bsteen81 is offline
Old 05-01-2006, 12:03 PM
Oscar_3748
Oscar_3748's Avatar
Default RE: Air Silencer
Locate you air box Where your air fliter is,
then remove it form the fender,
as you pick it up you will feel it right onder,
then just pull it off.
Bolt the airbox back to the fender!!!!- Done
Oscar_3748 is offline
Old 05-05-2006, 11:09 AM
bsteen81
bsteen81's Avatar
I dont get it? Someone help out?
bsteen81 is offline
Old 05-05-2006, 11:44 AM
StickShifty
StickShifty's Avatar
ORIGINAL: Oscar_3748
StickShifty is offline
Old 05-05-2006, 11:58 AM
mylongvictor
mylongvictor's Avatar
Ok here goes......
Steps:
1) Turn off car or leave car running. Up to you, it just gets hot under the hood when its running.
2) Pop the Hood and cast your eyes to the lower left hand corner of the comparment, right behind the passenger side headlights. You will see a cone shaped box bolted to the fender. Thats the air intake. (Kinda restrictive no? Get a K&N FIPK II!)
3) There should be one bolt holding it to the fender I belive. I can't remeber its been so long since I seen my stock air intake. Un bolt it, and maybe, just maybe there are two more holding it from the bottom.
4) It should come lose enough for you to pull it out slightly to see a tube running from the cone into the fender itself, just pop it out, chuck it away, and rebolt everything.
Entire process should take no more then 5 minutes and BANG! Your car is (barely) slightly louder at an idle and it may seem like you get a little more "get up" when you give gas. But hey, its free. Have fun!
mylongvictor is offline
Old 05-05-2006, 12:12 PM
SOHCtimes2
SOHCtimes2's Avatar
https://mustangforums.com/m_1135032/tm.htm
If you looked in the sticky at the top of the tforum you would have found this thread.
SOHCtimes2 is offline
Old 05-05-2006, 12:20 PM
monkeydude3
monkeydude3's Avatar
haha skill level "caveman"
it's a good writeup. I think I will go remove my silencer.
monkeydude3 is offline
Old 05-05-2006, 12:43 PM
monkeydude3
well I just did it. Total time taken to remove silencer, less than 5 minutes. result... not sure, leavin for school in 15 mins will report back later today
lmao
Old 05-05-2006, 12:54 PM
bsteen81
bsteen81's Avatar
What abouth the mesh screen in the MAF? Would that be worth removing?
bsteen81 is offline
Old 05-05-2006, 12:55 PM
monkeydude3
not really. I'd leave it as it protects the MAF. that restriction only becomes an issue with a heavily modded car
Quick Reply: Air Silencer
