Which springs are for me?
hey guys, about to make the jump on some lowering springs, and i was curious what brand and amount of drop would work for me.
01 GT, running 275's all around. the front tires rub a bit when im making a HARD turn, but i refrain from doing so. looking to get rid of that 4x4 look without running into trouble with the tires rubbing. i will also be adding LT headers in the future, so i want to keep those from becoming an issue as well.
any big difference between steeda, eibach, and the ford springs? thanks!
RE: Which springs are for me?
I have the steeda springs and they suck, It only lowers it an inch. You need to get a 2 inch drop to make it look nice. The eibach springs leave your car at a good height.
Is your car on 17 inch rims?
i'm gonna get the ford racing C springs sometime in the near future, and ive been told that ill scrape an aftermarket midpipe. just a thought for LT's
Ford racing C springs= 1.5 inch in front and 1.2 inch in back
i just had the H&R supersports put on with about 1.85 in in the front and 1.75 in the rear. i have 275/40 17's all the way around with no problems any where. if you want to see my cay look in my gallery. not quite sure how to put my pictures on here yet, just started my gallery.
i measured mine before i had the drop and the front sat .5 in higher in the front. so now it's a tad lower in the front or at least on some it will even them out.
the only difference youll see with a drop more in the front is a more aggresive stance. 1 inch drop eh? hmm im pretty sure ford racing makes a spring that doesnt drop that much.
Get Vogtland springs. They are perfect on my car with L/Ts. www.vogtland.com you can find them cheaper on ebay.
