Wheel locks but no key. Solution?
Old May 3, 2006 | 06:36 PM
newb2000GT's Avatar
newb2000GT
Default Wheel locks but no key. Solution?
When I bought the car used it had wheel locks installed and no key. Obviously I overlooked that detail but will need to get my wheels off eventually.
What is the best solution?
Old May 3, 2006 | 06:37 PM
03redGT's Avatar
03redGT
Default RE: Wheel locks but no key. Solution?
crying or a cold beer usually helps depending on your preference
Sean97's Avatar
Sean97
Jack hammer
Old May 3, 2006 | 06:43 PM
LilGuysWearBowTies's Avatar
LilGuysWearBowTies
OXY-Acetylene torch. No you can probably find a key for them. Like buy a set of lock nuts that looks like yours and use the key from that.
Old May 3, 2006 | 06:55 PM
koumiss45's Avatar
koumiss45
A 12 point socket will work. find one that is very close(slightly smaller) than the nuts themselves then use a malet to drive it on. Now you have a way t oget them off.
Old May 3, 2006 | 07:00 PM
03mustgt's Avatar
03mustgt
Is there any paper work on it? If not and they are the factory wheel locks your local ford dealer will prolly have a key for them.
Old May 3, 2006 | 07:24 PM
LvGordo's Avatar
LvGordo
get a socket big enough to fit over the lug, but not too big. Rough up lug with a rasp so stuff can stick to it (chrome off). Get some JB weld and pour it inthe socket (deep well works better) squish it on (wipe excess up off rim) let dry, then use socket to remove. Obviously this has to be done 4 x but easier than torching your rims and having to replace 4 wheels studs.
Old May 3, 2006 | 07:27 PM
blk40th's Avatar
blk40th
take the car to the dealer they should have a master key set that has all the different key locks. they might charge but then youll know what key you need.
Old May 3, 2006 | 08:12 PM
djdalfaro's Avatar
djdalfaro
Didja look in the spare wheel area? That's where mine was.
~Alf
Old May 3, 2006 | 08:23 PM
Stang9946's Avatar
Stang9946
I had this problem on one of my cars. Here is what I suggest. Find a socket that's barely too small. When I say barely I mean one that slides over about 25% of the lug. (Now you're going to have to be prepared to POSSIBLY wreck the socket.) Now take a hammer and slowly hit it over the socket. Not granny it but don't pound it like mad. If it's a decently made socket it should slide over the lug digging the sides into the lug creating a "bite". Now put a tire iron...or make life easier and air gun/impact wrench and spin that sucker off of there. Trust me, this works. Obviously you'll have to buy new lugs for the 1-4 keys you'll have to take off. Hope this helps/works. Let us know.
