Open Headers
Old May 4, 2006 | 01:20 AM
StickShifty's Avatar
StickShifty
Default RE: Open Headers
you will loose power, not alot, but a little enough for you to notice
Old May 4, 2006 | 01:55 AM
JT76's Avatar
JT76
Dont do it man, the car will sound like crapola and you will lose power rather than gain it, its a bad idea
Old May 4, 2006 | 02:13 AM
monkeydude3's Avatar
monkeydude3
first, will sound like crap. second, you will lose most of your torque/power unless you are forced inductin or have a massive high rpm cam. some backpressure is needed, otherwise your engine wont be able to run right. fuel injected engines repsond to open headers way different than carbureted engines.
third, YES IT WILL HURT YOUR ENGINE!!! Not instantaneously, but if left like that for prolonged time, it will burn the exhaust valves and eventually weld the head to the block. This is due to too little back pressure and see... the exhaust pipes do help take heat away from the engine... you take away that heat exchanger and the heat just burns up whatever it touches last a.k.a. the cylinder head and exhaust valves
and yeah you don't want a ticket for open headers.
George
Old May 4, 2006 | 02:15 AM
straitwangin's Avatar
straitwangin
a few people told me that you will burn up the valves because you dont have any back pressure. is this ture?
Old May 4, 2006 | 02:24 AM
monkeydude3
not so much the back pressure, but because if you have no exhaust beyond the headers, the heat is going to build up. Your exhaust system does serve as a giant radiator for some engine heat. Mostly heat from the exhaust valves and the cylinder head. No back pressure just makes a lot of engines run like a$$
Old May 4, 2006 | 02:31 AM
nick_thames's Avatar
nick_thames
ORIGINAL: monkeydude3
George
+1 Open Headers = burnt valves= lot of $ to fix
Old May 4, 2006 | 02:36 AM
BBond007's Avatar
BBond007
yep. and the exhaust fumes will build up under the car. C02. especially in high altitudes, like above 9000 foot where the air is lean, you could easily become asphyxiated and run off a mountain pass and die. Or live and just wake up with a crashed car and a pounding headache.
Old May 4, 2006 | 03:29 AM
97targa's Avatar
97targa
Way too LOUD, GET EARPLUGS. Also not good for your motors performance. It runs lean.
Old May 4, 2006 | 04:31 AM
rbstang's Avatar
rbstang
ORIGINAL: Master
gas milage will suck also
+1
my h pipe is leaking and i get 150 miles on 1 tank... 16 gallon tank...
150/16 = 9mpg.... so sad..
and my daily driver now is a 99 tahoe
250 miles on 20 gallon tank...
250/20 = 12.5mpg... even sadder.
Old May 4, 2006 | 04:40 AM
VARifleman's Avatar
VARifleman
ORIGINAL: BBond007
CO, not C02, is the big problem because it replaces the oxygen in your blood stream and basically suffocates you.
