valve stem seals?
RE: valve stem seals?
so im looking at finally doing this, since im already in the middle of replacing the timing chain tensioners and oil pump. I'm just concerned about the ease of replacing the lash adjusters and stem seals with the enging still in the car. I know it CAN be done, but it looks like there may be some clearance issues while using the compressor tool. Any advice?
I did this recently. But I had the engine on an engine stand. Its going to be really hard to do this with the engine in the car. You can get the valve covers out OK, but you have to get to the seals which are below the springs. To do that you must remove the springs. To do that you must remove the cam followers and the cam. To remove the cam you have to remove the front cover to get the chain off. To remove the front cover you must remove the front two bolts in the oil pan. To do that you have to remove the harmonic balancer, pumps, hoses, widgets, five golden rings and a partridge in a pear tree. I'm not trying to be discouraging, but it is doable, but not easily doable with the engine in the car. I described this from memory, so I might have missed something. And.....maybe I'm wrong. Anyone?
I already have the timing chain cover and chains off. However I was asking if anybody has done this work with the cams/springs still in the engine? It is possible to do it with the below linked tool, but i'm still not sure how easy it would be (clearance for the tool) with the engine in the car. Anybody try it?
http://www.toolrage.com/prodView.asp?idproduct=4464
I have used that tool and it works well. I had to modify mine a little bit for the romeo motors. You should be able to use it in the car just fine. I do my major repairs on an engine stand and thats where I used that tool fyi.
ORIGINAL: fyouceeku
In another thread OXFORDGT said that there is a 'spring stop' to go along with this tool to prevent bending a valve with the spring compressor. did you use that as well? thats again for the help.
ORIGINAL: pete1665
thanks man. Im just worried about clearance for the tool once I get near the firewall and strut towers. If you think it'll be fine i'll give it a shot then.
ORIGINAL: fyouceeku
i found the valve guide seals and lash adjusters at sean hyland motorsports here...
Seals - http://www.seanhylandmotorsport.com/...0277ad2f1f3691
Lash Adjusters - http://www.seanhylandmotorsport.com/...0277ad2f1f3691
these the correct ones? I think i might order the seals online, but my local parts store has the lash adjusters for about 10bucks a peice (which still seems like a lot) rather than sean hyland's 17bucks. anybody know somewhere else to get these parts? i've seen the lash adjusters a bit cheaper on ebay but im weary of buying them there.
I used that tool recetly for my dohc. and it can be done without removing the cam. I just had to modify the tool a little more to make it fit. There are clearance issues at least with me but once you get started and get the first one done the rest are easier .
