mine has slack in it, and i had ford run a diagnostic on it and they said that im getting perfect 100% throttle. so im not sure what the "mod" realy does, unless you have a serious problem.
yea most cars will, but some carpets are thicker than others, which may interfier with WOT. I know i get WOT when i floor it because i have a WOT switch and well... it works lol. but its mostly so that you can heel-toe the car, which is pretty much impossible with the stock setup.
i can't comment for the manual cars...but with my V6 Auto...the difference between the heights with the brake and gas pedals is really distracting...mine has about one inch of slack and i swear the brake pedal is higher than normal because i feel like i have to move my foot back like 4 inches to hit the brakes...it is really annoying
I thought I had a problem with that too on my 97 because there is a great deal of slack. So I hooked my car up to a scanner and floored it, and it said 100% TPS signal
