whinning
whinning
I have a 04 GT 5 spd, i just had 3.73's installed and about a week later i'm hearing this horrible whinning noise and it only does it when the car is in gear....soon as i take it out of gear it stops......is this a rear end problem? i'm positive that the backlash was perfect on it cause i watched them do everything what else could it be? my transmission has been acting up (grinding when i slam it in 3rd) could it be a possible tranny problem.....any input would be great..............thanks
RE: whinning
well i'd have to hear it, but i'm 100% positive its your new gears. Even though you had them professionally installed, doesn't mean they didn;t mess anything up. Gears are very tedious to install b/c they require precise placement. Take your car back in and have them mess with it. Either that or find somewhere that does nothing but drivetrain work, they'll know exactly what they're doing.
RE: whinning
Just because your transmission isn't in gear........doesn't mean the rear ring and pinion is not turning. If its the rear end, you would probably notice it more when you are slowing down or winding down if you're in gear.
RE: whinning
ORIGINAL: Sonicpilz
RE: whinning
ORIGINAL: Auto03
If so that is the problem.. and to fix it, replace them ASAP with the ford 4.10's!
RE: whinning
I have Motive 4.10's and I have no problem with gear whine. I have ridden in a Mustang that had real bad whine, his only whinned when he let off the gas and let the car wind down, or if he was coasting to a stop. It was usually around 40mph I think.
