Short Shifter Seal
05-09-2006, 10:44 PM
Short Shifter Seal
Is it ok if I dont have a seal/gasket on the shifter plate?
05-09-2006, 10:46 PM
I ♥ Acer
RE: Short Shifter Seal
I used RTV for mine. its fine.
05-09-2006, 10:57 PM
no, its not ok to NOT have any type of seal. Get some high temp RTV sealant and use that. It works just fine. Do NOT have no seal/sealant at all.
05-09-2006, 10:58 PM
Use RTV sealant, best not to gamble with something so easy and can be found at most any auto parts store.
05-09-2006, 11:05 PM
Quote:
ORIGINAL: dlazrael
05-09-2006, 11:09 PM
it takes an extra 2 mins to put RTV and it wont leak.
05-10-2006, 12:15 AM
Quote:
ORIGINAL: monkeydude3
just make sure it doesnt squirt down into the tranny when you put on the shifter (dont apply an ungodly amount)
05-10-2006, 12:19 AM
lol if u dont want transmission fluid anywhere i recommend the gasket maker! i used RTV... seconds to apply all worth it!
05-10-2006, 10:59 AM
Well if it is supposed to be leaking everywhere its not. Should there be fluid in the shift case when I open the plate? Cuz I dont really have any, just a little at the bottom.
05-10-2006, 11:36 AM
you just need a little bead all the way around... and all is well
baddog671
07-26-2016 01:20 PM
Explosive
10-02-2015 07:45 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
guitarman376
09-30-2015 05:54 PM
junior04
09-28-2015 10:53 AM
