NO BRAKES!!!!!!!
NO BRAKES!!!!!!!
i just got done installing my slotted rotors but there is NO pressure in the pedal. I havent had time to really look at it but i mash the pedal and just dont get much of a response. i did everything like i was supposed to i think. i did use a clamp to compress the dual front pistons, but they should come back out like they are supposed to as soon as the brake is pressed...... ill check the fluid level tomorrow first thing.. but with compressing the pistons there should me more fluid in the res right? i dont know what the problem is.... [:'(]
RE: NO BRAKES!!!!!!!
bleed your brakes... the abs system on the mustangs is rather complex. what you should have done with this particular car is open the bleeder, then push in the piston. And after the pads/rotors are on, bleed each caliper to be sure.
I'd try bleeding the brakes real good and see what it gets you.
I've noticed, with my brake swap... the pedal felt VASTLY different after the first drive... I bled them sooo much, but regardless of what I did, as long as I had not moved the stang, the pedal would fall right to the floor when running, the RPMs would drop and you could hear the vacuum fading.
As soon as I drove it, the pedal returned to normal and the sound went away... it's still a little mushy right now but I need to bleed again... been lazy with it because I can still trigger the abs at 90+ MPH
Make sure to bleed all four corners just to be sure.
After doing my brakes a few months ago the pedal and the brakes felt soft. What I did was pumped the brakes with the car turned off, then drive, then repeat. After I drove the car a little over half a mile everything was fine. Not sure if it applies to you since you say you're getting none, but figured I'd throw it out there for you.
bleeding does not require a special tool... I just bled mine two days ago... If you didn't disconnect the hose in any way, you shouldn't need to bleed them, but you'll never know if you don't try... and it only cost like 5 bucks for some brake fluid, and $0.50 for a damn hose... and if it fixes your problem, good. you may just have a leak somewhere.
ORIGINAL: Miliock
ORIGINAL: monkeydude3
by the way if i'm not mistaken the brakes are hydraulic, not vacuum... powered off the power steering pump
ORIGINAL: SpecterGT260
the haynes manual said not to bleed them because it requires a special tool. it also said bleeding wouldnt be necessary if the hose was never taken off the caliper.
Did you ever think to try pumping your brakes w/ the Master Cylinder cover OFF?? If you still get nothing, check your master cylinder itself.. Check the inside of your car, near your pedal assy for fluid..
You could very well have a bad M/C..
JT
JT
