Supercharger help...Vortech
Okay everyone I need supercharging 102 . I've already taken 101, but I need further educating.
I'm looking to a Vortech and am curious to know exactly:
A) How the different trims get their lettering (i.e. SQ, T, G, etc)? Is this because they produce different boost levels? Looking on the site it shows various psi levels based on trims, and different hp ratings, so I am assuming so.
B) Is there a benefit of going clockwise, counter clockwise, or straight?
C) What is all this V-1, V-2, V-5 stuff about[sm=smiley23.gif]?
D) Anybody here have a T-trim? Impressions? How loud is it? How quick does it build boost?
E) Can I implement a blower pulley on a centrifugal s/c like on a roots blower?
F) Finally, what is Adiabatic Efficiency?
~ After talking with Sutton HP and Ron at Fox Lake (I'ma get a forged shortblock[sm=badbadbad.gif]), it looks like the Vortech T-trim is the way for me to go, but up til this point the most I knew about superchargers were the different types (roots, twin screw, centrifugal) and how their power came about.
RE: Supercharger help...Vortech
ORIGINAL: GSXRIntensity
B) Is there a benefit of going clock wise, counter clockwise, or straight?
b. I assume you are talking about the gear cut? This will be decided for you when you order the blower style (SQ, T, etc) and what car it is for.
c. the V1 is the older style blower. I am not 100 percent sure but I don;t think vortech makes these any more. The V2 is more efficent, as it is the newer improved design. I have not seen a modular with a v1 S sieres on it .
d. Go to www.modularpowerhouse.com and ask in the supercharger or mongoose sections of their forums. There are plenty of people in there with T trims that can help you out. but iwth a forged shortblock otw they will tell you the same thing, get the T.
e. Yes you can pully a centri up just like a eaton or a twin screw. its all in the same principle. More a gressive pully for more RPM on the blower, and more boost.
F. I am not 100 percent clear on this, but I believe it has to do with how the blower transfers the energy from the stolen drive accesorys back into RWHP thru the engine. This relates to how much air is created compared to heat/friction etc etc. You really don't need to worry about it though.
EDIT: You really should think about going with MPH for your vortech install. The tune is great, the kit is totally complete, and the price is dead spot on. I am hours and hours away from em, they have never seen the car, and they tuned it dead on the very first time. I have been nothing but insanely happy with them.
I believe the adiabatic efficiency is how close the supercharger is to a PERFECTLY adiabatic cycle (one in which no heat can flow in or out or the s/c system). in other words, the higher the better, because you are turning more of the work you are putting into the s/c into heat and pressure and losing less of your input work to the universe. in other words, it's the ratio of the real s/c to the theoretically perfect s/c of that design. I think this may be hard to grasp unless you know a good amount aboot thermodynamics.
ORIGINAL: redass02gt
its not that complitcated to understand though. The higher the number, the more power to the wheels a setup will make (everything else equal). The lower the number, the more heat and friction steal from the RWHP number.
Thanks for all the help guys! I jumped on another forum and got some answers there, so between both places I have a better understanding now. I appreciate it!
