problem!!!
RE: problem!!!
alright it's in, but still sounds like it's leaking somewhere else. very frustrating. the pipe going to the passenger side header was hard to tighten maybe it's there? also got my mil elim's in the mail. go in each of the rear o2's? anyone have a little info on those? thanks
RE: problem!!!
i have not run my car without them since i took the cats off, so i am not sure if that is normal or not. I would assume that the light would come on eventually.
one end of the mil eliminator plugs into the o2 sensor, and the other to the stock harness. easy connection.
RE: problem!!!
ORIGINAL: sprostang
You could then splice the wires and extend them for a quick fix. I`ve never done that before but it can be done. I only needed to extend the rears. I used extensions though.
RE: problem!!!
loose exhaust hanger or your muffler is hitting your trunk like mine. When i installed my h pipe my flowmaster catback was welded for my stock h. with the h pipe installed the muffler is twisted so when i downshift the muffler vibrates and hits the trunk. You can see it in the picture.
