LOOK!!!!!!!!
LOOK!!!!!!!!
Hey
I have a 96 gt with 100,000 miles on it I’ve been using Mobil one 10w 30 synthetic oil but the car is burn oil should I change the oil to some kind of oil that is for cars with high milage is it alright to switch oils. I hear a lot of good things about royal purple would it be good for my particular situation
thanks
thanks
RE: What should it do
If you have just switched to synthetic oil it will burn some oil for the first 3,000 miles. When i switched to synthetic oil would puff out when i first started up but now it is gone. If not, you could switch to regular oil and see if that helps, but if is blowing smoke you have a problem with your rings and seals and they need to be replaced anyway so you would just be masking the problem. The 4.6 motor really likes 5w30 so i would use that.
