rear end
Old May 25, 2006 | 03:06 PM
01roush33's Avatar
01roush33
Default RE: rear end
read this.
http://www.corral.net/tech/drivetrain/gears.html
Old May 25, 2006 | 03:10 PM
01roush33's Avatar
01roush33
http://www.explorerforum.com/forums/...d.php?t=144780
Old May 25, 2006 | 03:25 PM
IownaMustangNow's Avatar
IownaMustangNow
this still isnt seeming to help. So do i nmot even hafta take the rear end apart? because i am not seeing anything about that thing that i shjowed in the picture.
Old May 25, 2006 | 05:37 PM
2VNA's Avatar
2VNA
Take it to a shop and have it done once and righ.
Old May 25, 2006 | 09:34 PM
IownaMustangNow
well after working on this thing for 3 straight hours we realized that we missed onbe crucial pouint in the instructions (gotta move back the ABS pick up) and when we realized that it was too late to do any thing cuz it was already getting dark . . way to frregen go. Also in the processtyhe two small gears fell out so we gotta get them back in. . . how fun! Turns out the s clamp really doesnt have anything to do with the axle, it holds the gears in. well just wanted to update my prgress. thanks for your help guys
Old May 25, 2006 | 10:10 PM
nitestalker's Avatar
nitestalker
the big clamp in the middle of your 3rd member does not have to be removed.you need to remove your pin.that goes trew your 3rd member the size is 8mm.remove the bolt and slide pin out.and then remove abs sensor at hub were axle slide in.then a half moon clip at the end of axle shuold slide out may need smal pick to shake loose.then the axle can be removed by slide out.
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
