NEED HELP ASAP PLEASE, CANNOT WAIT!!!!!!
Old May 29, 2006 | 12:02 PM
MustangMan528's Avatar
MustangMan528
Default NEED HELP ASAP PLEASE, CANNOT WAIT!!!!!!
i'm ordering my gears as we speak and i need to be to work in an hour. What all do i need to help me with the install. Bearing kit????? shim kit??????
Old May 29, 2006 | 12:12 PM
randy78045's Avatar
randy78045
Default RE: NEED HELP ASAP PLEASE, CANNOT WAIT!!!!!!
I'm thinking you need those things also... depending on where youre ordering your gears, you can always return the extra parts if you dont need them, that is, if you dont get a difinitive answer here before you go to work.
Old May 29, 2006 | 12:18 PM
Shawn02GT's Avatar
Shawn02GT
bearing kit if over 60k miles is recommended
Old May 29, 2006 | 12:48 PM
Hash06's Avatar
Hash06
you need a bearing kit it comes with shims and you need 3 pints of gear lube. go with royal purple
Old May 29, 2006 | 12:51 PM
sandcracker21's Avatar
sandcracker21
^^^also a good additive for that wont hurt
keep in mind that installing gears is a PITA
very tough job, i hope you know wut ur doin
Old May 29, 2006 | 01:50 PM
Fryguy22's Avatar
Fryguy22
Take it to a shop. That way if there is any gear whine you can always have them re-do it.
Old May 29, 2006 | 01:57 PM
randy78045's Avatar
randy78045
ORIGINAL: sandcracker21
You dont need additives unless you have clutches, etc in your rear end...
By the way, isnt PITA somethin you eat?
Old May 29, 2006 | 05:19 PM
Hyper00's Avatar
Hyper00
Just order the complete FRPP gear install kit.
Old May 30, 2006 | 08:13 AM
FDNYBullitt's Avatar
FDNYBullitt
Hyper is right, order the complete kit from someplace like Drive Train Direct, it comes with everything you need except for the pinion depth tool which you'll need to borrow from someone unless you have a friend that works at a Ford dealer, good luck.
P.S. Try to get a kit with Ford Motorsport gears or US gear, the others are a bit loud.
Old May 30, 2006 | 09:32 AM
Stang Bamf's Avatar
Stang Bamf
motives arnt loud
Nick Oliver
Oct 17, 2018 04:22 AM
fcarpio
Apr 30, 2016 05:31 AM
Jan 21, 2016 01:30 PM
DJ Piner
Sep 30, 2015 03:03 PM
mustangchef
Sep 4, 2015 08:08 PM
