people who have had a rough idle
how did you remedy the situation?
iac, tb sensor, o2 plug, tune up, sea foam, coolant temp sensor, ect...
would like to fix my rough idle and i dont know what to do next, i've done seafoam/tune up, maybe i need a colder plug. can you test the iac like you can the tb sensor?
RE: people who have had a rough idle
unplug the battery negative for a few minutes and reconnect and let it run for at least 5 min. if this doesn't fix it, try shutting the car off and pumping the brake about 4 times and then start it. hope this helps. i fixed a high idle this way
ORIGINAL: ackuric
