Help!!!!!!!!!!!!!!!!!!
Old Jun 3, 2006 | 09:13 PM
lucki96gt's Avatar
lucki96gt
Default Help!!!!!!!!!!!!!!!!!!
My car is smoking and making a squeaking noise, smoke is coming from the fan motor area then when I turned the car off coolant started coming out of the top. It's a 96 gt auto, I should just be able to replace the fan right.
Old Jun 3, 2006 | 09:20 PM
04BlueGT's Avatar
04BlueGT
Default RE: Help!!!!!!!!!!!!!!!!!!
Was the car overheating? Did the temp go up? If could be the fan, fan relay, the waterpump, or a thermostat.
Old Jun 3, 2006 | 09:25 PM
lucki96gt's Avatar
lucki96gt
yea the temp went up close to the red spot but something was burning in the fan you could smell the plastic. and thats were the smoke was coming from i unpluged the fan and didn't see anything. I am waiting for it to cool so I can take the fan out and have a look at it.
Old Jun 3, 2006 | 11:06 PM
bsteen81's Avatar
bsteen81
Is there any coolant anywhere? You may have a crack in your lower intake manifold or radiator, I had the same problem. Check and see if you have any spray on the hood or anywhere. Then, with the hood popped, start the motor and hit the throttle manually from the throttle body. Look for anything spraying on that area. Let me know what happens.
Old Jun 3, 2006 | 11:38 PM
lucki96gt's Avatar
lucki96gt
does the fan suppose to run when the the a/c is on with the car in park?
Old Jun 4, 2006 | 12:02 AM
ASUSMC's Avatar
ASUSMC
Yes if you turn the AC on (even if it is 0 degrees outside) your car will turn on the fan to pull air through the radiator. I think it is a really good design as it makes sure your car does not overheat. You might want to check your thermistat. It could be sticking and make the car boil over or overheat.
