How much power ??
RE: How much power ??
ORIGINAL: Gatorfan08
The most I would run would be 100. I was also thinking of adding a blower, but idk how well it would do b/c of 2v. Does any1 here have one installed on there GT ??
good choice man you would have been dissapointed with the npi car since you had the choice to go either way. As far as a blower on a stock motor, it depends on which one you choose, ie centrifugal, roots, twin screw, intercooled or non. LEts say you had an intercooled procharger runnin about 8 psi. You would probably see about 350 to the wheels maybe more. Not real sure about torq but that should give you an idea. DISCLAMER: I am just goin off of what I have seen on other cars and what others have said. No direct experiance.
Get the 99+, the npi gt's are pretty weak if i say so myself without decent money put into them. If you looking for quick 12's, get a 99+, and throw a 100 shot on it and call it a day.
ORIGINAL: Cornbread01
if your want to s/c it drop the compression to 8to1 with fodged pistions and run 12lbs of boost maybee even 13-14lbs of boost youll be happy
A stock engine'd GT is capable of 400+ WHP.
