Mod Help Please
Old Jun 16, 2006 | 10:52 AM
fright88's Avatar
fright88
Default Mod Help Please
Ok so I am looking at starting off my mods with a programmer and exhaust.
For the programmer I am trying to decide between the Diablo Predator or an Xcal II. Anyone know which if either is better and why. If I change my gears later can both correct Speedo and all that. Also is there a better programmer out there? I have heard a lot of good things about the X cal but that was on F150s/
Now on to exhaust. I am looking for maybe some power if possible but mostly I want it loud. My old mustang was using stoch H or X can't remember which is on the Mustang stock but had straight pipes from there and I grew to love the sound. This time I want to go with an actual system. It has to be emission legal so I won't be going with Long tubes and as far as other types of headers I am not sure yet. What are all of your suggestions.
I am looking at wither a Magnaflow or Flowmaster system. Since I am not going with long tube headers I can't justify paying over 200 more for SLP unless the performance increase will be significant. Like 3-10 HP more.
Anyways please give me advice thanks.
Old Jun 16, 2006 | 10:57 AM
P Zero's Avatar
P Zero
Default RE: Mod Help Please
Not sure about the Xcal or diablo ([:'(] EFI) , but as for exhaust, you should get a high flow cat pipe and flowmaster 40 series mufflers. Straight pipes might sound ok, but it actually hurts exhaust flow, flowmaster mufflers actually create a vacuum and the exhaust actually gets sucked out. YOull make more power runnin these than you would with straight pipes. Theyre kinda loud, but with a cat pipe they wont be too bad.
-P.
Old Jun 16, 2006 | 11:45 AM
bsteen81's Avatar
bsteen81
ORIGINAL: P Zero
-P.
+1 on the exhaust, as for tuner, if you are planning on adding any more HP I would wait until you have done a few more mods and then get a dyno tune at a speed shop. Dials it in a little better.
Old Jun 16, 2006 | 12:14 PM
fright88's Avatar
fright88
So you would not suggest a magnaflow or flowmaster cat back? Those are the 2 I am mainly looking at. Both can be had for under 430. Or would you recommend that and a midpipe?
Old Jun 16, 2006 | 12:40 PM
fright88's Avatar
fright88
Also on the Diablo would they not be able to use that to do a custom dyno tune at a local dyno place?
Old Jun 16, 2006 | 01:40 PM
bsteen81's Avatar
bsteen81
I would go flowmaster. Cant beat it if you wanna sound like a muscle car. Both are pretty even though. If you just want to be loud and obscene, go with SLP loud mouths, but they sound like crap(unless you like it).
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
