VT stage 2 cams question
Ok, i want to install VT stage 2 cams in my non pi stang (see sig). I know they wont make the best performance, but i just want it to sound mean. Can i install these cams with new springs and and 4.30 gears. I dont want to buy a stall.
RE: VT stage 2 cams question
I forgot to ask, what is the largest cam i can go with and wont cause any problems with piston to valve clearance and do i really need a stall or will the car still be drivable with out the stall with such large cams.
p.i. cams are the highest lift you can do i do have .550 and i am still doing good but remember it not the lift its the duration that kills you the bigger duration the more chance you have of have piston to valve contact
ORIGINAL: 03sonicgt
I wouldn't go any higher than a stage 2 cam. You will need a stall though.
My car definatly does not like to be ran under about 1500 RPM with the stage 2s. You will definatly want to get a stall with these or your probably gonna have major problems off the line, even with 4.30s.
ORIGINAL: monkeydude3
so other than idle, you can't cruise under 1500 rpm with those?
(now i know why my buddy's time's suck with his nova... he has a HUGE cam in it w/o a stall torque converter)
You defiantly would not want to try to launch from a idle etc.
hmm... my buddy's nova when he floors it off the line it kinda dogs until the rpms come up... i sincerely hope when he gets is 4 speed auto w/overdrive that he gets a stall!!! what would be good, like 2500 or 3000 stall?
I think is cam is comparable to a stage 3
and he's also getting 4.11s too eventually
right now with the haggard setup he runs 13.6... hopefully with the new stuff he'll be in the 12s
