strut ????
Old Jun 21, 2006 | 06:14 PM
afir's Avatar
afir
Default strut ????
I may have a bad strut but im not sure. Every now and then when Im cruzing around 20 Mph or so, If I hit a small dip in the road. I hear a scrape sound from the rear end. This also happens if I get on it when I take off and there is a dip in the road or weight in the back of the car. Does anyone know what this might be ??? I wanna take it to Ford and be specific on what I think it is because its still under warranty and I dont want them saying "its because of my mods".
Old Jun 21, 2006 | 06:19 PM
2VNA's Avatar
2VNA
Default RE: strut ????
Well no your car's not under warranty, those mods voided it alog time ago. where is the noise comming from, left right center, do you see any dammage?
Old Jun 21, 2006 | 06:25 PM
afir's Avatar
afir
The noise sounds like its coming from the right rear. I did look under the wheel well in the rear and found the sealent to be split a little in the rear left side. But no tire wear or anything.. I know im screwed with the warranty anyway.. I thought Id look for a friendly Ford dealer
Old Jun 21, 2006 | 06:29 PM
2VNA's Avatar
2VNA
Humm. i would take the wheel off and realy look at everything very close. If it's making noise it's making a mark. Or you have a fat friend have him jump up and down in the trunk. LOL sorry.
Old Jun 22, 2006 | 01:00 AM
racer02GTstang's Avatar
racer02GTstang
i am under warranty pushing 440rwhp with a supercharger and different tranny.....
just see if the car is bouncey or if you have any wet spots on the shocks to see if they have bursted. (im not sure if they are gas or liquid).
Old Jun 22, 2006 | 01:17 AM
04BlueGT's Avatar
04BlueGT
ORIGINAL: 2VNA
Not exactly. There is a lot of myths about this. I offer this article from Ford. I can't upload the .pdf file I have from Ford so here it is:
Modifying Warranty Awareness
Know that when you modify your vehicle, you may also be affecting warranty coverage
Editor's Note: A recent article in the SVT Enthusiast discussed the pros and cons of changing engine drive pulleys to help enhance power and performance. The story noted that one of the drawbacks to such an aftermarket modification is the possible effect it would have on the owner's New Vehicle Limited Warranty. When SVT's own Tom Scarpello read the story, he felt that the whole vehicle modification vs. warranty issue is one that deserves a little more than a cursory explanation, especially to performance-savvy SVT vehicle owners. So he asked Joe Bradley, the Manager of Ford's Warranty Analysis department, to add a little perspective on how certain vehicle modifications can affect the service life of some factory parts or systems, and how that may subsequently affect the factory vehicle warranty. The following is Joe's report.
By Joe Bradley
As you might expect from the company that formed SVT, the Ford Motor Company has many employees who are true performance enthusiasts -- folks who love and care for their personal high-performance vehicles as much as or more than the next guy or gal. Many of us, in fact, are true "weekend warriors" who can be found at the local drag strip or road course on Saturdays and Sundays, and tinkering under the hood during weekday evenings getting ready for the next event. As automotive enthusiasts, we certainly can appreciate performance machinery.
That said, as Ford employees we all want to do the right thing for our customers as well as for the Ford Motor Company. That is precisely why it is important to have a concise, easy-to-understand policy with regard to Ford warranty administration. For vehicles that are not modified, the Ford warranty policy is clear – the company backs its products within the guidelines of the new vehicle limited warranty, which is designed to protect the customer from defects in factory workmanship and/or material.
However, in the case of vehicles that have been modified, one needs to understand that the modifications may affect warranty coverage. This is simply because any damage or failure of new vehicle components or systems that was caused by modifications to the vehicle are not defects in "factory supplied" workmanship or material.
To illustrate this point, let's consider a small sample of vehicle modifications and see how they might affect factory components or systems:
When it comes to changing the factory engine drive pulleys, there are some powertrain system and component concerns that deserve consideration. One would be any electrical and/or charging system problems that arise because of reduced alternator operating speed caused by the installation of underdrive pulleys. After all, the performance and serviceability of many system components are based on certain design parameters that include operating speed. The same goes for problems stemming from higher cooling system temperatures because of reduced water pump flow caused by the installation of underdrive pulleys. Increased underhood temperatures caused by owner-induced changes to a factory design-specification part can have a detrimental effect on any number of powertrain components or systems – some that may have long-range implications. And things can get even more serious when supercharger pulley changes are made, including head gasket leaks and piston and connecting rod failures. Also possible is piston damage due to detonation from improper air/fuel and timing modifications.
The installation of any non-factory forced induction system can also cause problems. Base engines modified with aftermarket superchargers, turbochargers or nitrous oxide injection systems may indeed bring about some power gains, but they can cause piston, connecting rod and/or crankshaft failures as well.
Other parts of a vehicle's factory-spec drivetrain are also susceptible to damage when engine torque and horsepower is increased. Performance chips or other power-enhancing devices increase torque loads on the driveline and can force failure of the transmission and/or rear axle. The latter problem can be especially true when owners switch to wider tires or racing slicks in an effort to increase traction. Even non "go-fast" aftermarket accessories such as remote starters, alarms, supplementary gauges and audio equipment can cause electrical system service problems if they are installed incorrectly or have improper connections.
When it comes to fairly evaluating the possibility of a warranty denial, there's one simple rule of thumb to follow: Although the installation of non-Ford parts and aftermarket modifications, by themselves, will not void the Ford New Vehicle Limited Warranty, failures that result from these parts and/or modifications may result in a denial of warranty coverage for such failures or damage.
The bottom line is, Ford Motor Company wants each of its owners to enjoy their product to the fullest extent – and that includes performance vehicles. But dealer service technicians have seen, and continue to see, that modifications may cause the original design to fail. The addition of aftermarket parts is a risk that each and every vehicle owner must evaluate for themselves. All that's needed is a reasonable dose of common sense. When and if you modify your vehicle, please consider whether the modification may cause another component to fail – and if it does, recognize that warranty coverage for that failure or damage will likely be denied.
baddog671
Jul 26, 2016 01:20 PM
67STANGX2
Sep 24, 2015 12:29 PM
allenmaty
Sep 24, 2015 09:17 AM
