'98 Cobra in '00 v6
Old 06-22-2006, 12:48 AM
Alpha
Alpha's Avatar
Default '98 Cobra in '00 v6
I have a chance to pick up a '98 cobra motor and I'm thinking of putting it in my '00 6 banger. The engine is complete from intake to oil pan and comes with harness and the computer. What other parts would I need to complete the install? I would think transmission, rear end, exhaust? What else? Would that engine fit without any modifications in the '00 body?
Thank You.
Alpha is offline
Old 06-22-2006, 01:01 AM
St4ng07
St4ng07's Avatar
Default RE: '98 Cobra in '00 v6
I think the mounts would b different from it being a 6 cylinder
St4ng07 is offline
Old 06-22-2006, 09:56 AM
Alpha
Alpha's Avatar
Thanks for the reply. Any other opinions on doing this swap?
Alpha is offline
Old 06-22-2006, 10:54 AM
4.698GT
4.698GT's Avatar
You would need to revamp the front suspension to handle the extra weight of the 8 cylinder. No need to modify the body get it to fit. The rear end will have to be swapped, if you take it easy the 7.5 will handle it for a little while. An upgraded tranny would help something like a tremec or tko. The sixer tranny won't fit if knowledge serves me right. Hope this helps.
4.698GT is offline
Old 06-22-2006, 11:00 AM
mustangman02232
mustangman02232's Avatar
you need, a t-45 tranny, an 8.8 rear end, a new drive shaft, new motor mounts, does the motor have all the accessories i.e alternator, power steering pump, water pump? you will need those if you dont, also how much are you planning on buying the cobra motor for? how many miles?
mustangman02232 is offline
Old 06-22-2006, 12:38 PM
Alpha
Alpha's Avatar
I have Konis (yellow) all around paired with Eibach Sportline, so the suspension shouldn't be a problem. As for the water pump/alternator etc., I honestly don't know, but I'll find out. If not, could I take them out of GT? The motor has about 75K on it. I want to put a GT motor in it anyways, but now that this Cobra engine came up, it looks like it might be a better route to take.
Thanks
Chris.
Alpha is offline
11-10-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
Dan04COBRA
09-30-2015 11:46 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: '98 Cobra in '00 v6
