speaking of oil change....
RE: speaking of oil change....
Synthetic for sure. Mobil 1 is good, as is any brand synthetic over a conventional oil. All Petroleum Institute Approved conventional oil is fine as long as you change it frequently. Synthetic you can run much longer than regular oils before changing but only if you use a premium filter. I run full synthetic Royal Purple 5w-30 in my '98 GT vert. The car loves it. For that matter I run synthetic fluids throughout......engine, tranny and rearend. NAPA stores usually carry the Royal Purple line if you have such a store in your area. Otherwise you would have to go the mail order route. Pep Boys does carry the oil only. Below is a link for some background on synthetic oils you should find interesting:
www.royalpurple.com/techa/whyrpa.html
www.amsoil.com/storefront/xlf.aspx
http://www.redlineoil.com/products_m...=1&subcatID=14
