4.6 PI HEAD SWAP
Old Jun 25, 2006 | 10:52 PM
97mustanggton18s's Avatar
97mustanggton18s
Default 4.6 PI HEAD SWAP
ANYONE THAT HAS DONE THIS PLEASE GIVE ME SOME INFO...I COULD REALLY USE THE HELP WITH THE TIMING SO I DONT MESS IT UP.THANKS
Old Jun 25, 2006 | 10:54 PM
VARifleman's Avatar
VARifleman
Default RE: 4.6 PI HEAD SWAP
Remember to use 93 octane gas afterward because your compression ratio will be around 10.5:1 afterward.
Old Jun 25, 2006 | 11:01 PM
97mustanggton18s
YEA...I ALREADY PUT IT IN...DONT KNOW WHY
Old Jun 25, 2006 | 11:04 PM
06mustang88's Avatar
06mustang88
i don't know why either, nor do i know why you're typing in caps?? [&:]
Old Jun 25, 2006 | 11:16 PM
SXGT's Avatar
SXGT
I THINK THERE IS A STICKY ON THE PI SWAP BUT ITS PRETTY SELF EXPLAINITORY. YOU REPLACE THE INTAKE MANIFOLD AND THATS EASY , PRETTY MUCH IF YOU HAVE A WRENCH YOU CAN DO THIS.
Old Jun 25, 2006 | 11:17 PM
SXGT's Avatar
SXGT
HEADS TOO!!!
Old Jun 25, 2006 | 11:24 PM
Rantheman's Avatar
Rantheman
wow interesting posts so far.
Well anways do you have a romeo or a windser block the reason i ask is if you have a romeo block like me then your valve covers won't work with windsor heads or vise vurses. But its a pretty simple project. just replace the head gaskets, the head bolts, if you get the head new remember to plug a couple of the holes with plugs off your old head. remeber you will need a 99+ heater hose and nipple so you will need to remove your water pump to get the nipple out.
other than that 10.2 compression for me and get your car retuned it's not nessecary but it helps.
Rantheman's Avatar
Rantheman
i also did my swap for less than 900 bucks all brand new
Old Jun 26, 2006 | 12:04 AM
VARifleman's Avatar
VARifleman
*twitches* turn the caps off!
Old Jun 26, 2006 | 12:28 AM
jmmorgan82's Avatar
jmmorgan82
if you dont mind me asking, how'd you do it for 900 bucks?
