ENGINE HELP!!
Old Jun 28, 2006 | 11:49 AM
rayj1019's Avatar
rayj1019
I ♥ Acer
Default ENGINE HELP!!
This is a tough one...i have a 98 GT ...a while back i went thru a puddle while it was raining and sucked up some water...the car still starts and believe it or not idles fineee but theres a very loud noice comin from the engine.. tha sameee noise that you may make if your still moving and put your car into park with an automatic. It varies with the RPMs of the engine but only to a certain point then it stays at the same beats per minute, thats around 2200RPMs, anyways i pulled the valve covers cause i thought it was my heads...its not there perfect..theres no way i blew a valve ..and the bottom of the engine is stronger than the heads, its werid because the car doesnt run horrible when at idle it just makes a loudd!! noice. so im thinking that its a wrist pin..im gonna pull the block apart this weekend...any suggestions?? thanks
Old Jun 28, 2006 | 12:07 PM
monkeydude3's Avatar
monkeydude3
Default RE: ENGINE HELP!!
well before you pull it apart, pull all the spark plugs, and then hold the throttle at WOT and crank it and see if any water sprays out... it's worth a shot
Old Jun 28, 2006 | 02:12 PM
rayj1019's Avatar
rayj1019
I ♥ Acer
thanks
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
