aod shift kit
ORIGINAL: fiad06
does anyone know any brands of shift kits for an 02 gt mustang, i cant seem to find them anywhere?
also found these...
http://www.baumannengineering.com/aodecat.htm
http://www.tciauto.com/ford/ford_aod.htm
google is your friend.
With the newer cars you do it all electronically. You use a hand held tuner such as a predator or the like to adjust your shift points and firmness. This is sooooo much better than a shift kit because 1. you can always set it back to orgional and 2. you can install it yourself!
Hey 02yellowgt.....so ur sayin a tuner is much better than the shift kit? does that tuner work identical to the shift kit? cause i was told the shift kit is a lil better......i dont know i been wanting to put one on my 00 auto...i know the shift kit makes u burn 1st gear and 2nd or 3rd i believe
ORIGINAL: 02yellowGT
You bring up a good point. I have not done any reaseach into what auto tranny is in the newer GTs, but from what was said eariler it looks like it is the AOD-E. If so, B&M makes a **** improver kit for it.
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
