Smoked the clutch today
Old 05-12-2004, 06:13 PM
Nomad2day
Nomad2day's Avatar
Default Smoked the clutch today
Got a 99GT with a Paxtin Novi 2000 supercharger making 10 psi. Nailed it about 20mph and smoked the clutch this morning. It had 85,000 miles on it so it earned it I guess. Called the Ford dealership and they quoted $862.00 plus tax to replace the clutch, pressure plate, throw out bearing and resurface the flywheel. Turnaround is 2 days.
Does Ford have a heavy duty assembly I should ask for or is the stock unit fine?
Thanks for any info.
Neil
Nomad2day is offline
Old 05-12-2004, 07:06 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Default RE: Smoked the clutch today
The stock clutch isn't bad, but with your clutch I'd go for something better.
Dan04COBRA is offline
Old 05-12-2004, 09:22 PM
USAMuscle
USAMuscle's Avatar
I would request at least the FRPP clutch kit, which advertises I think 30% or 40% better holding power than stock. I don't know how much the dealership would charge for it, but at Summit Racing it's only $169.99. Just FYI, if you wanted to do the work yourself, it would cost you less than $300 total, including having the flywheel surfaced at a machine shop. Just something to consider...
USAMuscle is offline
Old 05-13-2004, 12:33 AM
Nomad2day
Nomad2day's Avatar
I will most likely do it myself after seeing the cost. Anything special I need to know about changing it out on the mustang. I have done it on my 68 GTO and 78 vette but not on a Ford?
What would be the clutch of choice?
Thanks
Neil
Old 05-13-2004, 10:52 AM
Moosetang
Moosetang's Avatar
One word "Centerforce"
Moosetang is offline
Old 05-13-2004, 11:03 AM
chriscindy6369
chriscindy6369's Avatar
I've been using a $179.00 King cobra Clutch Works Great for me and i have a 11.70 452 rwhp car 5 speed. At least i say so far so good.
chriscindy6369 is offline
Old 05-13-2004, 12:00 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
ORIGINAL: Nomad2day
Its not different than the other clutches you've done, except if your going with a stronger than stock clutch, its a good idea to install an aftermarket clutch quandrant - the stock ones are plastic and really suck, they usually start stretching before too long.
mdvaldosta is offline
Old 05-13-2004, 12:22 PM
Nomad2day
Nomad2day's Avatar
Thanks for the heads up on the clutch quandrant. Just got in from the night shift. I am going to go down and start pulling it out this morning seeing how it is raining anyway. I am a centerforce fan myself but I will see what all is available locally. What do ya"ll think about the aluminum driveshafts and flywheels? Worth the time? I have 3:27 gears now and will be putting in a 3:73 next month. I did not disable my rev limiter (about 6,000) for I am all over it now already, so I don't know if the above items are worth the cost.
Neil
Old 05-13-2004, 12:33 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
I'd replace the driveshaft if you're changing the gears, to prevent any drivetrain vibration problems that may occur (plus it saves weight and is stronger) - but you wont really notice any performance gains from replacing it though. As far as an aluminum flywheel, Im not a big fan of them in daily drivers, their much lighter than stock and will cause the car to idle rougher usually. The stock flywheel's wight helps with momentum to carry the engine over between cylinder firing and keeps things smooth, but the car will definately rev faster and that means more power to the tires. Oh and I like centerforce too
Old 05-13-2004, 01:59 PM
WS6speeDemon
WS6speeDemon's Avatar
hey i just bought a spec clutch, i haven't put it in yet but i'll let you know how it goes. I've hear that King cobra clutches are really good...
WS6speeDemon is offline
Quick Reply: Smoked the clutch today
