Steeda UDP's + Sound sytem + AC
Old 07-10-2006, 04:09 AM
GTowner4life
GTowner4life's Avatar
Default Steeda UDP's + Sound sytem + AC
Does anyone have a sound system and steeda under drive pullys together? I have an 800 watt amp with two RF P3's and want UDPs. Do they make your Air conditioning not work as good or cold as stock pullys?
GTowner4life is offline
Old 07-10-2006, 04:24 AM
so1o2k3
so1o2k3's Avatar
Default RE: Steeda UDP's + Sound sytem + AC
They shouldn't change how cold the A/C is. I'm not positive on this, but as long as your sound system is under 1000 watts the underdrive pulleys won't hurt anything.
so1o2k3 is offline
Old 07-10-2006, 05:02 AM
GTowner4life
Would you recomend a profesional install?
Old 07-10-2006, 05:04 AM
so1o2k3
so1o2k3's Avatar
You should be able to do it yourself assuming you have tools.
so1o2k3 is offline
Old 07-10-2006, 05:05 AM
GTowner4life
any links on how to? What about putting the belt on tight again? And can you run steeda UDPs with a supercharger?
Old 07-10-2006, 05:07 AM
so1o2k3
so1o2k3's Avatar
Whatever brand you buy the pulleys from should give you instructions, however many people complain that the instructions are vague. I'm pretty sure you can use underdrive pulleys with a supercharger.
so1o2k3 is offline
Old 07-10-2006, 05:09 AM
GTowner4life
Thanks. Maybe if my car craps out with UDP's and 800 watts i can buy one of those optimum yellow top batteries.
Old 07-10-2006, 11:39 AM
tcuallstar
tcuallstar's Avatar
ORIGINAL: so1o2k3
Actually you cant use udps and a SC... well you can but your blower is going to be turning alot slower due to the different crank size, so bottom line is, if you have any plans of a SC in the near future, stay away from UDPs
tcuallstar is offline
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
UrS4
09-30-2015 10:13 AM
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
Quick Reply: Steeda UDP's + Sound sytem + AC
