Best Caster/Camber Plates
RE: Best Caster/Camber Plates
Maximum Motorsports has the directions on their site, go to http://maximummotorsports.com/ and click on install instructions, scroll down to front suspension, camber caster plates and click on MMCC9994
So Steeda has more adjusable range than MM. Would MM have enough adjustment to get correct alignment with my Eibach springs and 18x9 wheels/tires? Or should I just fork over the extra cash and be safe with steeda?
ORIGINAL: joeybutts
MM!!!! They look great and allow tons of room for adjustability... blck98gt, how much did you lower your car that you can't have enough adjustability?
Thats the problem.. It has been raised back up and there still isnt enough adjustment... just wears the tires out everytime.
ORIGINAL: joeybutts
So you are back at stock level and you couldn't get their 4-bolts to align? I wonder how that is.. I'm just worried if i raise mine back up i am gonna have to change!
They are close to straight but from what lee rodgers told me they could be adjusted about 1% more to be 100% correct.. no big deal but if i go to drop it i think im gonna have to get new plates because they are adjusted to the max now..
