Ticking...
Old Jul 16, 2006 | 12:04 AM
02StanGT's Avatar
02StanGT
Default Ticking...
I have an '02 GT and I have just recently started hearing a ticking noise. It sounds like it is coming from the front of the engine, and it is only intermittent. Any help as to what it might be would help. Also I just replaced the belt, but everything appears normal to me. Thanks
Old Jul 16, 2006 | 12:09 AM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: Ticking...
Maybe a small exhaust leak between the head and manifold.
Old Jul 16, 2006 | 12:17 AM
damdanger's Avatar
damdanger
had the same issue, mine was the timing chain, yippie
Old Jul 16, 2006 | 01:03 AM
02StanGT's Avatar
02StanGT
I hope to hell it's not one of the timing chains. That's already happened to me once 1500 miles from home. The engine I have in it now has about 30k miles on it. I like the exhaust leak story, as this engine had headers installed on it when I put it in. Thanks, keep the suggestions coming please.
Old Jul 16, 2006 | 01:06 PM
02StanGT's Avatar
02StanGT
Bump bitches
Old Jul 16, 2006 | 01:11 PM
99gtstang's Avatar
99gtstang
could be alot of things...... timing chain stretched, cam caps loose, could be the fuel injectors---- stick a long flat head screw driver to each injector listen through then end of the driver... is the clicking just like that????? sometimes the injectors are loud..... Mine does the same thing.... has a 109 K though.......so i think my car is just a POS.... mine also stutters through out every gear.........
2000GTFOOL
96
Sep 4, 2013 05:45 PM
caddyman
Sep 8, 2006 03:21 PM
