Auto GT=high 13
RE: Auto GT=high 13
ORIGINAL: fiad06
My tires are new, only 2000 miles on them, and whats a stall converter.
ORIGINAL: racer02GTstang
gears and tires... stall and tires....
http://cgi.ebay.com/ebaymotors/EDGE-...spagenameZWDVW
There ya go. they are expensive, but worth it. I am going to get my shift kit, then tuner, then the stall tc. I'll be spankin 5 speeds in no time. lol
RE: Auto GT=high 13
ORIGINAL: mustangGTdude1031
go to ebay and type in AODE torque converter. Well, hot damn, I have a link. nvm.
ORIGINAL: fiad06
RE: Auto GT=high 13
ORIGINAL: fiad06
What is Torque Converter Stall?
Stall speed is the point where a converter has reached it’s maximum fluid flow or it has hydraulically locked up because torque multiplication has reached it’s highest point.
All stall speed ratios are approximate and will vary, based on the torque of the engine. Small and Big Block combinations will vary 300 to 500 R.P.M.’s Stall speed is the amount of engine R.P.M. that can be attained at full throttle with the brakes locked and the transmission in gear before the drive wheels turn. It is very important to determine that if your vehicle drive wheels turn before the desired stall is reached, you must either “flash” the converter to attain higher stall or install a brake proportioning valve that directs more fluid to the drive wheel brakes to better hold the vehicle. In either case, attainable stall ratio will not exceed 3500 R.P.M., due to the vehicle braking system, which is even worse with disc brake equipped cars.
RE: Auto GT=high 13
Gears and a midpipe took me from a 14.1 to a 13.5 and about 5 more mph so yeah. That was on street tires too so i think just gears should put you into the 13's, but tires would def help. Thats whats next for me.
