Underdrive pulleys
Old Jul 17, 2006 | 05:57 AM
WhiteFaleen2001's Avatar
WhiteFaleen2001
Default Underdrive pulleys
What would the best company be to go with? and secondly, who here has underdrive pulleys on their car and how have they been for you? What pulleys do you use?
Old Jul 17, 2006 | 10:23 AM
04BlueGT's Avatar
04BlueGT
Default RE: Underdrive pulleys
Best company is Steeda, hands down.
Originally, I installed MAC 'piggyback' pulleys. The stock crank pulley is mated to the MAC aluminum crank pulley and both are installed as one piece. Big mistake. It cause a vibration in the motor between 2500-2800 rpm, which in set of the CEL with a misfire code. So, after trying for two weeks to fix it, I gave up and bought Steeda pulleys. They are steel and there is no piggyback on the crank.
So, I've used both and can say that Steeda is fantastic. March makes pulleys also, just make sure you get the SFI approved damper, or you may accidentally order their piggyback version. They have both. You need to make sure which water pump you have. There was a change from the long shaft to the short shaft in 2001, so you have to figure that out. I don't know how to tell the difference, otherwise I'd tell you.
I noticed some gains (probably 5 rwhp), but Steedas allow the easy addition of their timing adjuster, which I also have. I have mine set to 14 degrees total advance. If you have a tuner or plan to get one soon, don't bother with the TA, as the tuner can adjust timing. Also, if you're planning on going the S/C route anytime soon, don't get pulleys; they don't work well with S/Cs.
Hope this helps. If you get pulleys and want directions, click this---> https://mustangforums.com/fb.asp?m=1478766
Old Jul 17, 2006 | 10:28 AM
1BAD3V's Avatar
1BAD3V
I'd go with Steeda or March, they both are good companies.
Old Jul 17, 2006 | 11:10 AM
sstang's Avatar
sstang
+1
Old Jul 17, 2006 | 11:23 AM
MustangChris04's Avatar
MustangChris04
steeda. Never had any problems. Highway mpg increased.
Old Jul 17, 2006 | 03:13 PM
wes ley n the G T's Avatar
wes ley n the G T
I have BBK UD pulleys and they work great never had any problems. Increased my hp by 6 or 7 on the dyno if I remember correctly. I'm getting an SCT tuner so I dont have to worry about not being able to use manual Timing adjusters.
Old Jul 17, 2006 | 07:02 PM
WhiteFaleen2001
According to mustangtuning.com, the BBK Pulleys are cheaper and provide more horsepower (10-15) while the Steeda's provide (8-10). Steeda is still better though?
Old Jul 17, 2006 | 09:36 PM
WhiteFaleen2001
anyone?
Old Jul 17, 2006 | 09:52 PM
Colorado_Mustang's Avatar
Colorado_Mustang
BBK is a piggyback[:'(]
Old Jul 17, 2006 | 09:55 PM
WhiteFaleen2001
Ok thanks. Are the MAC U/D pulleys any good? I know some selling a brand new set for $100 shipped. Are those piggyback also?
