will a higher octane gas offset a lean codition?
Old May 20, 2004 | 09:54 PM
04mustang's Avatar
04mustang
Default will a higher octane gas offset a lean codition?
if i put in 93 octane or octane booster in my car will it help my car if it is running lean
Old May 20, 2004 | 10:02 PM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: will a higher octane gas offset a lean codition?
If your engine is simply not getting enough fuel, higher octane gasoline will not do a damn thing.
Have the timing retarded a few degree's and driver her like a baby if you absolutely must, or have it fixed the right way...
Old May 21, 2004 | 06:40 AM
GSXRIntensity's Avatar
GSXRIntensity
ORIGINAL: 04mustang
No. If anything you should run 87 until you get a Dynotune, because running 93 on a stock GT can cause for some pretty hard starts. It did with mine. I ran 93 for 6mths when it was stock, & it ran surprisingly better w/87 in it until I had it tuned.
Old May 21, 2004 | 10:03 AM
WHT00GT's Avatar
WHT00GT
dynotune,dynotune, dynotune.... they can fix your a/f's in a minute. then you have no more worries about running lean....
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
