When do i...
Old Jul 19, 2006 | 06:57 PM
avlon06's Avatar
avlon06
Default When do i...
When is a new clutch and flywheel needed? like when you reach a certin hp or what?
Old Jul 19, 2006 | 07:06 PM
mylongvictor's Avatar
mylongvictor
Default RE: When do i...
Well alot depends on how you drive your car. If your power shifting every gear etc. I changed mine at 15k.
At HP levels. Your Stock clutch is good to around the high 300s. When you start getting in between 400 and 500, Stage II or King Cobra with a Aliminum Fly wheel is my recomendation.
Old Jul 19, 2006 | 07:17 PM
MustangChris04's Avatar
MustangChris04
All depends on the factors. My stock clutch started slipping as soon as I got my drag radials. The radials really did a good one on my stock clutch. After you get your tb/plenum I would put in a clutch and flywheel and then get lt headers. Just make sure you do the clutch and flywheel before you put the headers in. I think if your making 300rwhp your stock clutch will go pretty fast, but it all depends on if you have sticky tires and how much you race your car. Your car will feel faster with an aftermarket clutch, when you shift it will just hook real hard and pull you back. I recommend mcleod.
Old Jul 19, 2006 | 07:20 PM
03sonicgt's Avatar
03sonicgt
Stock clutch here with 40k on the clock, 4:10's and drag radials. Its ALL about the driver.
Old Jul 19, 2006 | 07:42 PM
avlon06's Avatar
avlon06
How much is a mcleod?
Old Jul 19, 2006 | 07:45 PM
krm486's Avatar
krm486
ORIGINAL: avlon06
When the old one breaks!
Old Jul 19, 2006 | 07:46 PM
avlon06's Avatar
avlon06
King cobra clutch or a spec stage 1?
Old Jul 19, 2006 | 08:37 PM
avlon06's Avatar
avlon06
any opinions?
Old Jul 19, 2006 | 09:34 PM
monkeydude3's Avatar
monkeydude3
king cobra FTW
cruising it feels stock
when i slam the hammer... chirps 2nd gear and i get a nice kick in the seat shifting to 3rd (NPI 4.6)
highly reccomend it.
Old Jul 19, 2006 | 09:45 PM
avlon06's Avatar
avlon06
and its much cheaper to
JayyVee
Oct 18, 2012 10:50 AM
dlazrael
Jun 26, 2012 10:54 AM
qball
5.0L V8 Technical Discussions
Jun 18, 2011 12:18 PM
frdmstng1986GT
Aug 6, 2006 12:26 AM
Speedyrae
Feb 4, 2006 06:59 PM
