99-04 Stangs
RE: 99-04 Stangs
ORIGINAL: avlon06
Why is that?
Well, if you want to use NOS, get a '99. If you are gonna s/c it get a 2001+
RE: 99-04 Stangs
ORIGINAL: bsteen81
Compression rate is high on the 99 & lower on 01+. you need low compression for s/c unless you get forged internals.
ORIGINAL: avlon06
Why is that?
RE: 99-04 Stangs
ORIGINAL: 04BlueGT
The '99 was the first year of the PI head I thought? If I'm right, then the compression should be about the same as the '04, or 8.5 if memory serves.
ORIGINAL: bsteen81
ORIGINAL: avlon06
Why is that?
98 = non PI
RE: 99-04 Stangs
ORIGINAL: SXGT
99 = PI
98 = non PI
ORIGINAL: 04BlueGT
ORIGINAL: bsteen81
ORIGINAL: avlon06
Why is that?
98 = non PI
Okay, I've had enough fun tonight. Bed time.
RE: 99-04 Stangs
the trannys have synchro problems but that's with all of them 99-04... T45 and the 3650, I believe the actual gearing in the tranny is differant between the two... not sure how big of a differance, but there is one... there is a TSB for the synchros though...
RE: 99-04 Stangs
ORIGINAL: xxkazp3rxx
hey man, how do you like your 3.90s? how fast can you go in 4th gear?
