Lowering springs?
Lowering springs?
Can I just replace the springs without doing the rear control arms for now?[&:] I really want to lower my car. Im so sick of the 4x4 look. For those that know about lowering, what do you suggest I do? Thanks.
RE: Lowering springs?
you can do the springs without modifying the lca's. However depending on what spring drop you do if you go lower than 1.5" I would reccomend you get caster camber plates. Either way you will need a good alignment for the front when your done to be on the safe side. The other rear suspension mods can wait till you have money etc and its all a matter of what you intend to do with your car dd, track etc.
ORIGINAL: sprostang
Cool. Thanks. What about my shocks? Can I keep them or do I need get different ones? Also, will I have any issues with the pinion angle?
i dropped mine a inch and a half with eibach spring kit all around . thing rides sweet didnt have to get a alighnment or anything no wear on the tires either the 2 inch drop looks way better tho wish i did that but u will probably need caster plates and ****
Heres the springs I think i`m gonna go with. How hard will they be to install?
http://mustangtuning.com/eibach-pro-...-04-coupe.html
I'm not sure why people continue to preach that you DON'T need new struts/shocks when you do Upgraded springs..
Not only is it incorrect, since the original struts/shocks are valved to go at stock height, the vast majority of times, the shocks will blow out for several reasons, shortly after installation. Between a higher spring rate, less suspension travel and more than likely, a more aggressive driving approach will yield some potentially dangerous results..
Sure you don't HAVE to change them, but why risk it?? Also, would you rather do the work twice, or 3 times, or all at once??
Have fun...
JT
Have fun...
JT
+1
ORIGINAL: GodAmGT00
Have fun...
JT
Have fun...
JT
