Solid Motor/Trans Mounts
Old Jul 26, 2006 | 03:03 PM
JimboGT01's Avatar
JimboGT01
Default Solid Motor/Trans Mounts
So i heard about these a couple of days ago and did a little looking up. I guess what they are supposed to do is stop the flex in the mounts so the power is forced down the drivetrain instead of turn the motor a little. My question is does the trans mount do the same? how much does this really help? Where to get them and how much?
TIA
Old Jul 26, 2006 | 03:23 PM
GodAmGT00's Avatar
GodAmGT00
Default RE: Solid Motor/Trans Mounts
Every part strengthens a part..
I think engine mounts are fine.. Tranny mounts aren't really necessary until you really start putting a good amount of power to the ground.. The Tranny mount pretty much just holds the tranny up enough, since solid mounts would keep your engine from torquing back and forth..
JT
Old Jul 26, 2006 | 07:46 PM
droptoppony's Avatar
droptoppony
I've asked a few race car builders about this and they all said if you drive the car alot just replace your old ones with new stock mounts...the solid can cause a vibration is your car...they said the tranny can be a nightmare. IDK i've never used them myself but i will be using stock replacements when the engine comes out.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
