Best MAF?
Best MAF?
I want to upgrade my mass air flow meter. Which one should I get? Will I actually see noticeable gains? Currently all I have is a programmer, cai, and weld in flows. Should I get something else performance wise instead of this? Gears are out of the question right now.
RE: Best MAF?
ORIGINAL: red99gt
RE: Best MAF?
he wont see a differance BUT if you continue to put **** into your engine its a good building ppoint. i plan on doing an entire top end kit on my car BUT before i cna order that i ordered a new 70mm tb, 75mm maf, 225lhr fuel pump, and 24 lb injectors. it was 800 that i didant know i was gunna need for the other mods i wanted to do BUT now that i have it i cna do alot more,
RE: Best MAF?
Now this is just what i heard. I heard that throttle bodies and plennums are a waste of money unless you have enough mods to require all that air flow. Your engine will only induct as much air as it needs. So basically it is a waste of money unless you plan on bigger things later on, but it wont do anything now. CORRECT ME IF I HEARD WRONG!!
RE: Best MAF?
ORIGINAL: DROES99STANG
