garage floor
Old Jul 30, 2006 | 07:04 PM
robs400's Avatar
robs400
Default garage floor
I just bought a house and I finally have a garage for my stang....however the garage is pretty much the basement of the house because its located on a hill, so the walls in the garage are mostly concrete. The garage is very damp and has a small puddle that stays the same size over in one of the corners. The walls have previously been sealed and they appear dry however the floor is damp in several areas. I'd like to speckle paint the whole thing, but need to seal the concrete first. I checked out the dry lok systems at the local hardware store and they are only waranteed for walls, not horizontal surfaces. Does any one have any input on what coudl be used? Any help would certianly be appreciated. Thanks everybody.
Old Jul 30, 2006 | 07:10 PM
Cornbread01's Avatar
Cornbread01
Default RE: garage floor
first etch the surface with meratic acid the let dry out for a day or two then buy some armorseal 1000 (illigal in cali, but can buy it in reno) use 2 to 3 coats expensive paint but far the best its about 150 for 2 gals....it is a 2 part apoxy
Old Jul 30, 2006 | 07:11 PM
randy78045's Avatar
randy78045
ORIGINAL: robs400
I painted the floor of my garage... requires an acid wash... primer coat... an paint... not as difficult as it sounds... all products from home depot...
Old Jul 30, 2006 | 09:58 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
I would try and figure out the standing water problem first, it is a clue that somthing is not right in the foundation. You should never have water in your basement.
Old Jul 30, 2006 | 10:02 PM
Knight Mare's Avatar
Knight Mare
Congrats on the house.
Old Jul 30, 2006 | 10:09 PM
randy78045's Avatar
randy78045
ORIGINAL: JD1969
JD is right... and the way you explained that you are on a hill, its possible all you need is drainage... a 55 gal barrel an submersible pump... ok.. over simplified... but up north where i grew up this was a problem and just putting a pump about 3 feet below the floor may take care of the problem...
Old Jul 30, 2006 | 10:18 PM
JD1969's Avatar
JD1969
I had to pass on my dream house because of a bad foundation with very bad water problems. It was an 1898 Victorian, the price was great untill I went into the basement, it would have cost another $150,000 to fix the foundation (the only way to do it right would have been to lift the house, move it and pour a new foundation)[]
baddog671
Jul 26, 2016 01:20 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
