[Deleted]
Old Jun 4, 2004 | 04:58 PM
  #21
Birdieman4's Avatar
Birdieman4
Default RE: C&L vs. Densecharger
Here's a question: If you did a C & L plenum without upgrading the throttlebody, would you even gain any hp? -Say on a stock 04 gt.
______________
02 S281E Saleen
Old Jun 4, 2004 | 05:06 PM
  #22
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
yes, even on an otherwise stock setup I'd say 4-5 hp
Old Jun 5, 2004 | 03:24 PM
  #23
Deleted User's Avatar
Deleted User
I ♥ Acer
Default [Deleted]
[Deleted by Admins]
Old Jun 5, 2004 | 04:30 PM
  #24
04mustang's Avatar
04mustang
for the c&l system u have the maf kit- the inlet pipe -TB and then the plenum.
MAF KIT AND INLET PIPE PACKAGE = $350
TB & PLENUM WILL BE ANOTHER $300 AND CHANGE
WHOLE INTAKE SYSTEM AROUND $700
Old Jun 5, 2004 | 05:18 PM
  #25
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: mdvaldosta
Acutally the T/B makes almost no difference at all. I have seen a report on the C&L setup where they swapped in the MAM/inlet pipe/k&N, and gained like 15 HP or whatever they gained (can't remeber) then put a T/B on and only gained 3 more RWHP.
That was swapping from a stock 65 mm to a 75 MM
Old Jun 5, 2004 | 05:26 PM
  #26
04mustang's Avatar
04mustang
i think the bigger TB change is for the plenum to work better. u prob do get 2hp off the TB i dont doubt it. the plenum is where the hp is. i would just change the plenum leave the TB alone. 160 bucks for 2hp nah i dont think its worth it buddy. especially on the newer stangs the TB is already 70 so changeing to 75 is not that big of a diff. but older stangs might benefit from the bigger TB. if your on a tight budget i say just get the plenum.
Old Jun 5, 2004 | 05:30 PM
  #27
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: 04mustang
This is what I was trying to say. Without the T/B you will see basically the same gains as with it (on either c&L or densecharger setup)
Old Jun 5, 2004 | 05:41 PM
  #28
04mustang's Avatar
04mustang
agreed
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
Camster
Sep 10, 2015 11:18 AM
