Taking off Top Strut Nut HELP
Old Aug 2, 2006 | 10:16 PM
gtboy2k's Avatar
gtboy2k
Default Taking off Top Strut Nut HELP
Is there anything special I need to know to get the top nut on the strut off? And is it possible with hand tools, becuase I dont have any air tools. Thanks.
Old Aug 2, 2006 | 10:24 PM
gtboy2k's Avatar
gtboy2k
Default RE: Taking off Top Strut Nut HELP
O and what is factory torque for the strut nuts?
Old Aug 2, 2006 | 10:44 PM
crash94's Avatar
crash94
From my sn95 Chilton's book - 141 to 191 Ft lbs. Don't see why it wouldn't be the same for a 00' model.
Old Aug 2, 2006 | 11:54 PM
JPGT_00's Avatar
JPGT_00
I used a impact gun on mine. I may be mistaken but I think the top of the strut has a groove so you can probably use a heavy duty flat head screw driver.
Old Aug 3, 2006 | 12:28 AM
sitnlopro99gt's Avatar
sitnlopro99gt
If you do not have air tools and your just trying to lower it so you can install springs you can just undo the nuts on the topside of the strut and then lower the whole a arm with the floor jack and everything will fall right out. If your trying to replace the struts I heard the sell the tool u need to remove the nut at any sears where they sell craftsman.
Old Aug 3, 2006 | 12:30 AM
sitnlopro99gt
ORIGINAL: JPGT_00
You end up doing it that way the screwdriver is going to slip out and you chance scratchin the sh*t outof your fender plus you dont really have any good leverage their. I tried and almost had that happen and I said ok bad idea so I wouldnt reccomend it to anyone.
Old Aug 3, 2006 | 12:28 PM
gtboy2k's Avatar
gtboy2k
I am not trying to replace the strut, just trying to install some MM caster/camber plates. So I will need a tool from sears to remove the top strut nut?
Old Aug 3, 2006 | 01:49 PM
monkeydude3's Avatar
monkeydude3
ORIGINAL: gtboy2k
I just did that on mine!
Bud... you'll need an impact. I tried a wrench and a screwdriver, broke a screwdriver and almost broke my hand when the screwdriver slipped out. Went to my friend's house who has a compressor (I dont' have one yet) and you just zip it right off.
And to tighten it down, just zip it back on with the impact. I have no noise or loose issues on the CC plates with mine from doing that
ooo while you have everything apart check your ball joints for play. Mine have like 1/2" of movement, it's crazy i'm doin those this weekend too
Old Aug 3, 2006 | 02:06 PM
97BlackStang's Avatar
97BlackStang
I belive they are called draglink sockets. Sears has a set of four for 20 dollars. THIS is what you need to do it.
Old Aug 3, 2006 | 02:08 PM
monkeydude3
well God da**it! oh well they're already done. The impact makes it much easier
