the fastest N/A stang!!!
#22
RE: the fastest N/A stang!!!
yea his compression is good for the giggly gas not a s/c/turbo. the key to running low times is mostly suspension. and the reason you dont see that many n/a 2vs is because they are soo damn hard get alot of hp without f/i
#23
I'm pretty sure code possibly has one of the fastest cars on here period. With the giggle gas, I think he wants to run 10's, I may be mistaken though. But he defanitely has the fastest n/a stang on here.
#24
The actual compression ratio really means anything. Its your cam that really decides what your actual compression ratio is. You can have an 11:1 compression with a turbo on it, but have a cam that allows overlap and more duration so it lets some of that air escape while its heading to TDC to lower the actual compression ratio.
#25
ORIGINAL: avlon06
are you ever going to s/c ur gt?
#27
ORIGINAL: 97mustangt
Damn I didn't realize it was still a 283. Is it the cams and intake that help a lot. Code could you share the trick that really pushed you over the 300 mark?
#29
i made 309 through stock shortblock and pi intake. unfortunately i spun a rod bearing due to an oil starvation problem (a simple canton oil pan would have prevented this) before i could install my ported bullitt and re tune it, i was gunning for 325 n/a stock shortblock. i've given up n/a and had a forged motor built for boost.
#30
Buy the way the fastest N/A 2v stang actually ran a 10.49 The guy was from michigan. I'll try to find the page I saw his car on. It was a blue sn95. It was being advertised as worlds fastest 2v NA stang. I'll look around though.
