threw it in first instead of 3rd
so i raced a car the other day, and while trying to shift into third real fast i hit first instead. now my question is, do u think i fuked ne thing up? it runs fine, first gear seems fine, no grinding, its not hard at all to put in gear. but i thought there was a device that kept u from puttin ur car in first above like 30mph. and im afraid i might have broken this device. my friend broke his pressure plate, i think he said, from putting it in first while going to fast.
RE: threw it in first instead of 3rd
I wouldnt be worried about you transmission. I would be worried about your engine. Thats like over revving your motor and your motor cant do anything about it. When you floor it and hit the redline, the fuel is cut off and the revs stay bellow a preset amount. When you down shift your mechanically over revving your motor from the spped which your driving at. I hope you dont go to far past redline. You could basicly down**** in first like you did and over rev your motor till it blows. How high did it rev up too?
If it still runs fine you probably didnt hurt it. Listen for any new sounds that might be coming from the trans. Mine will go into any gear anytime I want, so i dont think theres anything keeping it from going into first at any speed. I would be more worried about over reving the motor when you did that, but if it still runs fine i would just be more careful next time.
You might want to consider an aftermarket spring loaded shifter. It moves the shifter to the right automatically when you shift from second to third so you dont have that problem of going into first like you did.
ORIGINAL: Aixtreme89
2. do u mean how far did it redline when i put it in 1st, or what rpm was i at when i was at the top of second?
if u mean, how high did it rev when i hit first, honestly i wasnt watching that, i immediatly pushed the clutch in and hit the brakes. i would guess almost to the end of the redline [:@]
ORIGINAL: andrewclark
1.well, when i WOT, i get a couple 100 rpm's from redline and shift, i never go past redline.
okay, i think its fine, just trying to be sure. also, did u say its bad to downshift? or is it just bad when u downshift and it redlines while downshifting?
